What does pinging sound like?
Hello,
I am a real rookie in the world of automobiles but could someone describe what pinging sounds like? Is it just a noise or can you feel it as well? I think my car has it. Is it the same as detonation?
Thanks!
Thanks!
BB's bouncing off sheet metal, kind of a mix of a "tink" and a "tap" (how are those for unscientific terms!). I'm working out a pinging problem myself with a chip for my 2000 1.8T. HTH.<p><a href="http://registry.audiworld.com/audi/registry/details.asp?car=2361">
<img src="http://pictureposter.audiworld.com/AudiWorldPics/2000/jasonh_aw_sig.gif" border=0></a>
that's far worse than some minor pinging. If your car makes the noise you describe I'd suggest you to to have it looked at...it's hell on bearings and con-rods.
Regards,
James R.
For sale 24,500 all mods listed plus all orig parts including turbo included in this price.
99 1.8TMS (Neuspeed K04, 5 Bar FPR, Beru Ultra X Plugs, K&N Filter, Remus Exhaust, S4 Wheel Well Liner Mod, Bilstein Sport Shocks, Neuspeed Sport Springs, Neuspeed Front Anti Sway, Brembo Rotors, Mintex Red Box, Ronal R-7's 17", 225/45/R17 Bridgestone S02 PP, Smartire (neat gimmick), Greddy Turbo Timer, European Projectors, Clear Sides and Full Tint...)<p>
Regards,
James R.
This happened only once since my apr ecu upgrade. The oil temps were low (170-190F) and from what I recall the coolant temp was not yet up to par.
Basically It occured a few minutes after pulling out of my driveway (car was not "fully warmed" and I got on it a little because i was running late.....I know, I know).
I think Im gonna get it checked out..just to be safe. Any other thoughts on this?
It has only happened ONCE~ 17k
Thanks,
Nick N.
99.5 turbo A4
mods
Thanks,
Nick N.
99.5 turbo A4
mods
Do you feel a loss of power or a hesitation when this happens? If you say it only happened once it's not ping..when the car pings it will do it whenever you get on it really hard. Or when you drive semi agressively in hot weather as the intake charge temps go up a tad, which makes pinging even more of a problem.
Roll all 4 windows down and take off from a stop...wind it all the way out to about 5~6 grand. You'll hear a ticking noise that comes and then goes, that would be ping...you'll usually here it once for each of the 3 lower gears. It goes away cause the computer makes timing adjustments until it has forced the knock sensor output below the detection threshold. It's a feedback system...it works nicely.
Regards,
James R.
Regards,
James R.
It sounds exactly like a low volume "ping" sound...sometimes twice in one gear. Arrggh to the you the truth I would get this low volume ping before I chipped the car-but not the before mentioned "slap" (serious detonation) sound. **** now Im concerned. Thanks for the info James..I'll see what more I can scrape from the archives.
:T
Nick N.
99.5 turbo A4
:T
Nick N.
99.5 turbo A4
those golf clubs in my trunk...sorry guys, i just had to. (just got back from a round of golf).<p>Chard
99.5 1.8tqms Silver, APR, clear corner mod, exhaust mod, some stereo stuff...
