What does a radiator flush cost?
I went in for an oil change last week and the tech recommended a radiator flush. I declined because I was planning on taking it in to the dealer for 60k servicing soon. Turns out, 60k servicing is not much more than an oil change.
Today I got a temperature alert on the dash. I have a feeling it is radiator related. Anyone know the average cost of this service?
Car is a 2001 A4 1.8T.
TIA
TIA
You really want to start thinking about doing the timing belt service at 60K. You can search the archives for examples of premature failures, costs, etc. With the overheating (?) issue, you have another reason to do this. With this timing belt service you'll have to replace the coolant, water pump, and thermostat, which addresses some of your concerns. Still you'll want a mechanic to diagnose the issue, in case it's determined that you need a new radiator, fan switch, whatever. Anything causing the overheating will be easier (hence cheaper) to address while the TB service is being performed.
Yesh
11-28-2005 02:54 PM
evilaudi01
06-04-2005 03:07 PM
Sully
20
11-02-2004 02:01 PM
Is there a tech write up or step by step directions for timing belt/water pump/60K service? Is there
I AM 2ks4
9
02-26-2004 07:38 AM
