What else could be causing my car to misfire and run rich?
with your mods it could be many things. Boost leak may be the most common problem. Which MAF do you have - they were updated around your year. it could be the old one or a defective one. Another guess could be if your plugs are gapped way too much - but then again I am not sure that would produce black smoke...
Are you getting misfire DTCs? in which cyl(s)What is your primary O2 readings? If you do some datalogging with rpm, O2, MAF and other stuff you can get help troubleshooting it.
BTW - YGM...
BTW - YGM...
or 2nd gear going steep uphill so it won't rise up to fast. Then a few of us may calculate what's going on. Do it part throttle (like 50% acceleration) and WOT - as those are two separate programs
Is it only smoking and misfiring during idle? cruising or hard acceleration?
they might misfire at idle... stoplights, stop
and go traffic, etc... and run too rich at
WOT. if you recently installed new plugs, take
em out and look for carbon deposits.
Just VAGd my car. Im having misfires on cylinders 4 and 6. My idle is rough. New spark plugs? I also
BlackS4tt (Josh)
02-13-2005 01:42 PM
EVIL-AUDI@Audizine
VAG-COM Discussion
08-12-2004 04:35 AM
JimmY@RojoCollisioN
12-08-2003 08:28 AM
