What is everyone's opinion on stock superiority? AEB vs. ATW vs. AWM
Old 05-31-2007, 03:17 PM
  #11
AudiWorld Expert
Mr. Mom's Avatar
Default That would be my recommendation
and I will pursue this same path when required.
Old 05-31-2007, 09:58 PM
  #12
DVS27t's Avatar
Default had a 2000 before and will stay 2000
21mm wrist pins, small port head will make more power until you start playing with big 35R's. has 9.3:1 compression
Old 06-01-2007, 05:57 AM
  #13
qfrog Ti20's Avatar
Default I dont think any used 21mm wrist pins
Not even the highest output factory 1.8T 240hp had 21mm wrist pins. The 240hp variant used the same rods as a 90hp 4cyl engine from about 20 years earlier. Same rods in the 1988 Audi 80 2.0 4cyl those rods are also in the AEB. Everything I've read indicates that you get 19mm or 20mm wrist pins. I can check this on tuesday but I believe 058 blocks AEB/ATW used 20mm whereas 06A/B blocks used 19mm. Both 144mm long for 86.4mm stroke.
Old 06-01-2007, 07:33 PM
  #14
DVS27t's Avatar
Default sorry it was 20mm i hit the wrong button typing it last night. same as AEB and all TT225 engines
2001+ are 19mm and is much weaker.
pal joey
01-05-2018 10:11 PM
DG94
Audi allroad
9
12-02-2012 09:41 AM
OlyS4
Q5/SQ5 MKI (8R) Discussion
10
09-20-2011 07:25 PM
Quick Reply: What is everyone's opinion on stock superiority? AEB vs. ATW vs. AWM
