What exactly is the function of a bypass (or blowoff) valve?
I only recently learned what the wastegate does, since my turbo suffered the infamous "broken wastegate rod" issue.
I learned that the wastegate bleeds off extra boost on the exhaust side, so that the exhaust gases don't even spin the turbine.
So what does a BPV do? Does it bleed off boost on the cold air side? If the turbo has a wastegate, why is a BPV even needed?
Just curious...
-- P.
Just curious...
-- P.
lag between shifts even worse. Assuming you take your foot off the gas when you shift
bootnet
05-26-2004 11:43 AM
tgray
07-19-2002 09:02 AM
