What kind of grease to use on short shifter install?
#11
Did you forget to put the small circlip on? If you didn't forget, it might have come off...
when it is down, the blue link thing is probably hitting the bottom of the tray in there...
#12
The circlip around the shifter itself (the one you have to take off to get the whole thing apart) is
on. That was the only one that I was aware of. It isn't exactly small though, it's close to 2 inches in diameter.
#14
Check out step 20
You will notice part "M" that is a small circlip that holds the ball part down. Once you put it together and slide the ball down as far as it will go, there is a groove right above it that the clip slips onto and holds it from moving. Did you keep all the leftover parts?<ul><li><a href="http://www.bmracing.com/media/products/pdf/25.pdf">push</a></li></ul>
#17
Yes I did, thanks. The snap ring actually didn't work though...
the snap ring was too think, and for a different spot on the shifter. There were 2 little silver c-washers that came with the kit, I used one of those and clamped it into the slot with pliers. Doesn't move a millimeter now. I think I'm going to pull the whole thing out and adjust it so the whole shifter sits lower though. The middle setting feels a little high.
#18
Those 2 c clips were for the nylon bushings that go on the brass rails.. check out my writeup
<ul><li><a href="https://forums.audiworld.com/a4/msgs/2539568.phtml">push</a></li></ul>
youcantseeme
04-30-2006 02:23 PM
JeepRage II
03-19-2005 03:10 PM
scott12v@pghaudi
9
11-25-2002 01:01 PM
