What kind of tranny fluid do you Northeastern's run?
I'm thinking I need a change. Not sure what brand my Audi indy shop put in (i do know it was synthetic), but I wanted to know what specific kind you guys are running. Shifting is still crunchy in this cold weather and its bothering me.
Red line for the trans. However, to me, it seems its only good for about a year. Then you have to flush and fill with fresh. Red line= top shelf, however, its racing fluid, so its not a "life time" or good for "100,000 miles" type of oil.
I change mine every 20K miles(some will say "its a waste")
<img src="http://pictureposter.audiworld.com/13510/redline.jpg">
But i have switched the rear diff with the Facrory GL5 lube.
<img src="http://pictureposter.audiworld.com/13510/dscf0009.jpg">
About your trans feeling a little crunchy, that pretty much normal at cold temps with this trans.
A few thing that you can do, not to hurt that 2nd gear syncro is, double cluth 1st gear, double clutch 2nd gear, make sure your doing about 8-10mph, when getting out of your driveway/down the street.
Pretty much double clutch all gears, until you get some heat in the trans. NO F1 STARTS!!!!
but in conjunction I'd like to get a better fluid in there. Since my shop replaced the fluid about 6-7K miles ago, im skeptical to know what fluid is in there now.
it seems to be a little bit better but I'm thinking thats just because its new fluid. If I did it again, I would try some other aftermarket fluids as the Audi stuff is $30 a bottle and you need 3 bottles.
Double clutching allows you to shift when it gets cold out. My 2nd gear hates anything below 45 degrees F
