what kind of transmission for 1998 ATQ motor
No problem running the ATQ, but asking what trans goes with that car and engine is confusing. The answer is "none" since Audi never built that combination. What you really want to know is the trans type for a 1998 with a 30v V6.
Just for the record, you may not have a real ATQ. I replaced an AHA with an ATQ. They are mechanically identical, but to do a total swap you need to replace the gas pedal mechanism to do the total drive by wire conversion. In my case it was easier/cheaper to put the AHA's intake, throttle body and other peripherals on the ATQ.
So now the motor is still stamped ATQ, but it's really a drive by cable AHA.
As you state: the only difference between ATQ and AHA is the throttle body.
From what I see it is drive by wire.my problem is I have the motor in the car but it wont start.they say my problem is that the atq motor takes 2 cam sensors,a crank sensor and an rpm sensor that goes on the transmission.im hoping if I just buy the transmission it will fix my problem.if not my other solution will be to purchase an original 12v motor with harness and ecu.I feel that would be more work then just trying to find the transmission and getting it started.does anybody know where I can find a 2000 engine harness diagram?
Now I'm really confused. Sounds like the problem is your ATQ won't start, and you're trying to solve it with a new tranny?
Before you throw a tranny at that problem, you need to take some VAG-COM codes so you know what the issue is.
Second, the 98 didn't have a 12v motor. It had the AHA, which is mechanically the same. As stated before, when I swapped an ATQ into an AHA car, I left all the drive by wire stuff behind so I didn't have to worry about the harness and ECM and the DBW gas pedal. That's a pretty easy swap.
I think you need to know your problem before you throw more parts at it. And a 12v motor is going to make things more complicated: not easier.
This a deal yes the car doesn't start.I used vag com and got a code for that the crank sensor isn't reading.my car is a 1996 and they swapped in a 30v atq motor but left the original 1996 transmission.I don't know what transmissions I can use for 1998 atq motor non quattro.from what I've heard the car will not start if it doesn't have a rpm sensor connected where the 1998 or newer transmission has the hole for it.the reason I made this thread was the mechanic that has my car says to make this swap work I need the transmission that goes for this motor or I can just swap in an original 12v back in with harness and ecu.
trust me guys im just as confused as you guys are about this situation
