What numbers to the wheel or crank can I expect from this set up with custom tuning?
#11
around what a K04 might be able to produce) Anything larger than this will be loud for no reason. Possibly consider doing 3" test pipe tapered down to 2.5" exhaust.
#12
Yes books are nice to read, but there is something called "hands on experience". Maybe you should try it some time.
So for my 700hp should I be running a 5"+ exhaust?
#13
But ... the design of the exhaust at the wg and exducer will impact the VE of the engine and the time to spool.
The 'need for backpressure' comes from NA engine exhaust requirements and, as the article says' is an unfortunate byproduct' of the desire to have high gas velocities to help scavage cylinders. With a turbo it is all about getting boost pressure. The sooner and greater the boost (greater within reason) .. the better for torque in a turbo system.
#14
Still a member of the flat earth society huh?
'don't baffle me with facts .. I've got my mind all made up'
The principles of ideal exhaust design don't change if you are running a small turbo or a huge one ... just where the diminishing returns begin on sizing.
#15
oh wait no I dont since I dont live in the Northeast. I live in Socal were we have things called hills and mountains. Hell even the tracks I run at range from sea level to 3k feet.
I find it funny how plenty of people that tried going to 3" exhaust with a K03/K04 found they loss low end tq because the boost threshold changed. But I guess you think those people dont know what they are talking about either.
#17
(including the downpipe) and then 2.5" from there back. Thus creating less restriction right by the turbo, but then tapering to something a little more docile (in the sound category)
#18
a good amount quicker. Granted going to 2.5 probably would have yielded the same result.
#20
He is talking more on the lines of controlling the amount of back presssure as you increase the hp, that is not the same as taking a K04 and trying to decrease the back pressure even more which just changes the power band.
