What r the benefits of the oversized oil filter on our cars?
#11
Although whatever deleted posts in my UID is probably from mods deleting my post if inappropriate for the forum, or posts getting deleted by users that I may have responded to.
In anycase, I choose to admit failure, so I'll let it be![Smile](https://www.audiworld.com/forums/images/smilies/smile.gif)
I'll just follow up with correction post below it
#14
lower aids are having memory loss and going back to noob status, so I'm a noob
![Big Grin](https://www.audiworld.com/forums/images/smilies/biggrin.gif)
#16
Check out this link and if interested see what the guy has to say about paper filters and the differences in the stainless mesh type filters. I ran the smaller auto filter for well over a year and they really keep the oil clean.
Paper filters filter oil by the flypaper method. Oil is forced against the paper and whatever sticks is considered filtered, they in fact bypass almost all the time. These are the same filters (screen media not actual filter) that is used x 3 on my dry sump. You cant beleive what it catches and keeps out of your crankcase. Read this b4 you pay too much attn to paper filters. once in the site you can navigate to his tech stuff. This guy was a BIG TIME drag racer as in nat champ multiple times. I also really like his oil. The info opened my eyes about filtering.
Rod<ul><li><a href="http://www.gopurepower.com/site/products/#42">Lifetime oil filter that actually filters</a></li></ul>
#18
How did the paper filter function incorrectly here?
<a href="http://photobucket.com/" target="_blank"><img src="http://i15.photobucket.com/albums/a364/AudiJunkie/122k_miles.jpg" border="0" alt="Photobucket - Video and Image Hosting"></a>
...and here?
<a href="http://photobucket.com/" target="_blank"><img src="http://i15.photobucket.com/albums/a364/AudiJunkie/DSCN5155.jpg" border="0" alt="Photobucket - Video and Image Hosting"></a>
10k intervals on Syntec 5w-50, 1996 Audi V6 12v
...and here?
#19
But what really convinced me they were worth every penny and then some was when I spun a rod bearing and heat warped a crank. At any rate
And I didnt say the paper filter was bad I said the stainless positive flow filter is better. I think the proof is on the site.
Every piece of the bearing ended up inside the filter housing. This would not have happened with a paper filter, I would have had to replace mains thru and maybe a custom block instead of rod bearings and a new crank. I spun the bearing in the mountains and it was probably 15 minutes until I noticed I had a new noise, then I had to baby it home 35 miles to confirm the bad news which is also the reason I run dry sump now. But anyway talk to the guy who runs the company and he will more than convince you if my experience didnt.
Rod
Retail Price: $199.95
Item Number: 8400
Availability: In Stock
Compare The Facts!
SAE TESTS
(Southwest Research Institute) Pure Power! Lifetime Oil Filter Name Brand "Throw Away" Oil Filter Vehicle Engine Oil Pump Flow
Filtration Rate (not screening material micron size) SAE J1858 25 Micron No Restriction. Filters down to 5 micron particles. 90% more efficient than throw-away oil filters. 5 Micron Material Oil is 12 Microns; it can't go through a 5 micron material. *Oil flows BY, NOT THROUGH. N/A
Burst Rate SAE HS806 Ch 9C 1,000 psi 150-300 psi N/A
Flow Rate SAE HS806 2001 20 GA per Min 2-6 GA per Min 6 GA per Min.
By Pass Open 16 lbs 6-8 lbs 6-8 lbs
O-Rings VitonĀ® Rubber/Buna
Filtering Media Dual Woven T304 Stainless Steel Paper/Cellulose
Housing Construction 6061 T-6 Billet Aluminum, CNC Machined in USA Stamped Metal
Qty Price
1 $199.95<ul><li><a href="http://www.bobistheoilguy.com/whatisoilanalysis.htm">Oil analysis page - clack</a></li></ul>
Rod
Item Number: 8400
Compare The Facts!
SAE TESTS
Qty Price
