This is what running lean will get you...
A final pic of the carnage from cylinder #1 rod breaking:
<img src="http://www.audizine.com/gallery/data/500/6850Carnage.JPG">
Then, you get to do stuff like this:
<img src="http://www.audizine.com/gallery/data/500/6850No_Motor_1.JPG">
This is what I did on Saturday. Two guys and a little less than 8 hours with carefull documentation of everything. Hopefully it goes back together like it should.
We have a few parts to order today and we sending the torque converter to Level 10 to have Sam and the boys beef her up some.
it. I had a PES T-28 kit installed for a few weeks and it was running lean. I couldn't get the guys at PES to do anything other than tell me that they don't believe me. It's not worth talking about, I just will NEVER deal with them again.
In the end, I believe the motor was running lean enough to over heat the cylinder walls and seize the piston in cylinder #1 first. That then caused the rod to let go. This all happend on the Interstate with the cruise set at 74 mph.
but not a con rod, with an unscathed piston. Either poor oiling, or too much boost is my bet.
i think it was also PES? not positive though, it windowed the block like yours.
he wasnt beating the car either, just cruising.
driving or riding in the car. I only knew something was wrong from running VAG logs for CAPS times and general checking. Several guys I work with all had ride in the car and thought everything sounded perfect.
