What tools do you need to take rotors off?
the rotor is only attached by the wheel bolts. Once the caliper is removed the rotor should come right off unless it is stuck on with rust. If this happens, just take a rubber mallet to the rotor to knock it off (please make sure the car is properly secured on jack stands otherwise you could get really hurt or damage your car).
Go to the bottom of the article linked below, it describes how to remove the front caliper.<ul><li><a href="https://www.audiworld.com/tech/wheel1.shtml">https://www.audiworld.com/tech/wheel1.shtml</a</li></ul>
Is it hard to replace rotors? Should I take it to the shop, or is it a DIY for a technicaly inclined
maaliish
05-24-2001 10:39 AM
A4Driver
10-09-2000 11:26 AM
