What triggers brake pad light?
99.5 A4 Q, 2.8. A couple times in the last week I've seen the brake pad warning light in my LCD, like the one in this list. I have lots of pad on the fronts, about 1/8 inch on the rear, and the resevoir is between max and min. And I don't see any wires coming out of my pads to trigger this. I 'm thinking this is a false alarm, but how do I turn it off and what triggers it?
![](http://mtroxel.com/audi/warning-symbols.jpg)
https://forums.audiworld.com/search....archid=4000565
friend of mine made some modifications to his suspension and now brake pads keep lighting up time to time, some worn cable he sais. You could check that out also,
the pads activate when a metal connector inside the pad material touches the brake disk, and that happens when the pad is worn out, otherwise the metal con. is covered in pad material
![Stick Out Tongue](https://www.audiworld.com/forums/images/smilies/tongue.gif)
