What would cause my car to run lean and go into limp mode?
Old 07-27-2003, 08:29 PM
  #11
AFturboA4's Avatar
how did you check for leaks in the hoses?
Old 07-27-2003, 08:30 PM
  #12
AFturboA4's Avatar
another thing is it will only stay in limp mode for about a day or less and then i am back to normal
Old 07-27-2003, 08:31 PM
  #13
AFturboA4's Avatar
i haven't replace the DV yet but i have one right now that i am going to install soon
Old 07-27-2003, 08:32 PM
  #14
Magnutz25's Avatar
Default I can email you the pictures tomorrow
we basically just sealed from the MAF to right before the engine.........hooked up an air compressor and listened and felt for air......
email me tomorrow an I will try to help you out...I am on my way to bed
Or IM me tomorrow night
marcmagnone@clearchannel.com
AOL IM = Magnutz25
MSN IM = marcmagnone@hotmail.com
Old 07-27-2003, 08:33 PM
  #15
Magnutz25's Avatar
mine went switched back for a little while, then eventually stayed limp
Old 07-27-2003, 08:46 PM
  #16
'Bahn Burner's Avatar
Default Man, what is this, bad MAF meter week. Just replaced mine on Friday...
from vwparts.com for $185 shipped (delivered in 2 days!)
Old 07-27-2003, 08:52 PM
  #17
Default vag-com codes to check:
Log these data blocks:
032 - Long-Term fuel trim at idle and under throttle. The first two values should be within -10 and +10 and relatively close to each other. If the first is negative and the second is +18 or higher, MAF meter is probably bad (Mine were -.5 & +18.4 before replacing MAF meter, and -0 & +1.4 after replacing).
211 - Provides actual and calculated expected MAF values. Log this datablock while driving and see how the values match up.
Old 07-27-2003, 08:55 PM
  #18
AFturboA4's Avatar
could it be my coolant temp sensor??
Old 07-27-2003, 08:58 PM
  #19
ArandA4's Avatar
Default With my DIY leak detection kit
A leak probably wouldn't cause you to go lean though. In fact, it'd have the opposite effect. You're getting too much air.<ul><li><a href="https://forums.audiworld.com/a4/msgs/1659806.phtml">Click here</a></li></ul>
Old 07-27-2003, 09:29 PM
  #20
ArandA4's Avatar
Default Actually, you were rich, just not in the monetary sense
2 Faults Found:
16806 - Main Catalyst: Bank 1: Efficiency Below Threshold
P0422 - 35-10 - - - Intermittent
17535 - Fuel Trim: Bank 1 (Mult): System too Rich
P1127 - 35-00 - -
Quick Reply: What would cause my car to run lean and go into limp mode?
