Whats the best way to flush coolant on my 1.8?
My car has gas leaking into the coolant somewhere and I need to flush it bad. Whats the best way to do this? And where are the bleeder valves?
Thanks!
(1999 b5 a4 aeb 1.8tq)
Thanks!
Till I can fix it.
Took it to the mechanic and he said that it was gas in my coolant. The tank is like a thick goopy yellow right now =\ I just spent 2k on the car so the head gasket will have to wait
http://www.blauparts.com/audi/audi_fluid/audi_coolant_engine_fluid.shtml#audiv6coolantchang e
Haven't done the coolant yet but maybe should. Most folks do it with the TB change.
So a temp fix will have to do =(
My mechanic recommended it so I'm gonna give it a shot. It works for aluminum blocks/radiators so it can't really hurt anything
If you do it will clog up the heater core, can plug up the radiator and just make a general mess.
I've done it on one car and will never again.
BTW, I'm a certified mechanic too, here's your second opinion.
-richard
-richard
I just did a visual inspection and it doesn't appear to be leaking around it or the hoses. It's quite clean. Seems like the oil leak may be above it though and a bit more towards the front of the block.
What else could cause oil in the coolant? could it be something internal in the oil cooler?
