What's a lightweight 19 inch rim that I can get for around $800+ per rim?
#18
I like the Kinesis wheels more than the Fikse's, mostly because they don't require a spacer, which adds a few unseen pounds. Last time I checked, the Fikse's required a spacer on S4's, but not A4's, unless you're running an upgraded brake kit. I could be wrong here. I like the look of the HRE 545 a lot, but I'm not sure where they fall in terms of weight. I'm not even sure the Kinesis wheels fall in your weight range. You should probably check with Kinesis first.<ul><li><a href="http://www.kinesismotorsport.com/">http://www.kinesismotorsport.com/</a</li></ul>
