Wheel bearing replacement
Hi guys,
my gf's 2001 A4 has some wheel bearing noise that's been getting pretty bad lately. I have replaced entire hubs on cars, but it looks like the bearings on the audi need to be pressed out and and new ones pressed in. I'm not 100% if it's the front or back bearings at this point. When I did her brakes a while ago, I noticed her rear hub looked to be sligthly out of alignment on the driver's side - this caused the brakes to squeal in the back every once in a while. I have had this on the list to replace (hub and bearing) - but it hasn't appeared to cause enough problem to do it just yet.
Now, there is hub noise which SOUNDS like it is coming from the front of the car - so it may be a good time to do all the bearings...
My questions are - what brands do you recommend? The cheapest I've found appears to be on Blauparts - about $76 for a pair of fronts and $100 for the pair of rears.
My plan is to take the brakes apart, disconnect the housings from the control arms, etc. - and then bring the uprights to a machine shop I know to press the new bearings out/in. Are there any steps I should be aware of with this plan that might suprise me? Any special tools?
I've never done press fit, and don't have a press obviously - so I don't want to get caught with my pants down on anything. Any thoughts from the people who have done this or have knowledge of the process would be great. Thanks!
When I did mine I used this from Harbor freight: http://www.harborfreight.com/fwd-fro...ers-66829.html
Worked great and didn't have to remove the whole knuckle and take to a shop to press it. Get the CV out of the way and your good to go.
Most aftermarket bearings are going to be *** brand. Most of these are China made and are hit or miss for quality. My last *** bearing was Canada made and has held up for 40+k miles. Best are German OEM bearings and can be sourced from the dealer. Not sure about price, but I've heard they are not that pricey.
Thanks 5V/cyl! I will check out the tool. I have a machine shop guy that I think gets a bit of a kick about my DIY stuff on Audis. I take things in to him and often he doesn't even charge me. I have a feeling he'll do all 4 of these knuckles for me for about $75...but it would be nice to be able to leave the knuckle in place....I've seen things on the forum where people say they had trouble with a 20 ton press getting the bearings out...so I'm a bit nervous...
Thanks again for the input..
I used this, got it for $99.
http://www.harborfreight.com/12-ton-...ess-33497.html
Also, when you press the hub out the bearing will separate and you will have to chisel the front half of the bearing off the hub, its a little bit of a pain but gets easier once you've done it a few times. A bench vise is a must.
Here is the tech article that I used.
https://www.audiworld.com/tech/wheel44.shtml
Good luck!
Aarock_32
12-14-2010 07:25 AM
Pat
Rocky Mountain Discussion
02-11-2003 09:20 AM
skabaru
02-04-2003 12:36 PM
JTravinski
10-08-2001 05:53 AM
