wheel bearings (searched already)
I'm looking to get an actual part number for both the front and rear wheel bearings for 98.5 1.8tqm.
I've searched and come up with two different part numbers for the rear's.
8D0598625A and 8D0407625A. Which one is correct?
I've also got a number that someone posted that was stamped on the side of the actual bearing. FAG567447B, but they didn't know if that was for a front or rear bearing.
I deal with a few different bearing manufacturers, and was looking to try and save some cash by getting the bearings from them, but I need the correct numbers for them to cross reference.
Thanks for the help.
I read that post as well before I posted and it still doesn't mention anything about the part number for the fronts.
It also doesn't clear anything up if that part number is infact the part number that replaced the earlier part # 8D0407625A.
His post is also one of the reasons I posted. There is uncertainty, seeing that the kit he got had a different size bolt. His car is also a 2001, mines a 98.5. I doubt there is any difference, but was just checking to be sure.
<center><img src="http://pictureposter.audiworld.com/32880/removinghubpas.jpg"></center><p>and i can check out to see what it says the part# is are you planning on getting both front and rears?
I've got one of each that I think are on their way out. Noise from the right front and the right rear. So I figure I might as well get parts for all of them. I imagine the other two will be soon to follow.
OWDLVR
11-22-2007 05:50 AM
OCDaudi90q
02-12-2004 05:39 PM
