The wheel guide broke off in my hub...
I found a nail in my tire today. After driving to the dealer because I was not supplied with the tool to remove the lug bolt covers I swapped wheels. However I don't think I screwed the wheel guide in all the way and the wheel broke it off. So now I have about 1/4" of hollow plastic screw stuck in the hub. Any ideas on how to remove it?
basically its a reverse threaded drill (left hand) so as you drill it in (backwards) it actually is backing out the right handed threaded portion that is stuck.
I tried the needle nose route, but it's completely broken off inside the hole and I couldn't get it to take. I can't really cut a slot since the screw is mostly hollow. Maybe just cut it to the thread in a couple places and scoop out the parts?
steel piece from www.ultimategarage.com that will serve the same purpose. If screwed in properly, it will support a 50 lb wheel easily. I love this thing!
