Which wheel has a higher probability of rubbing the fender. Both wheels have 235-40-18 tire.
well that's tough. Because the upper control arm is an issue, then the fender is the other one.
So you could choose more offset, but then you'll need to roll your fenders/raise your car if you're on coilovers
the rear i'm not sure about.
not sure if that helps you any but on stock ride height there isn't any rubbing at all...but its a tight fit to say the least lol
18x8
Offset: 38mm
Backspacing: 5.94"
Bolt Pattern: 5-112
Rec. Tire Size: 225/40-18
Weight: 16.8lbs.
18x8
Offset: 38mm
Backspacing: 5.94"
Bolt Pattern: 5-112
Weight: 16.8lbs.
Almost no clearance b/n tire and rear upright too (like maybe slide a pencil through) That being said, I really don't think 8.5" et45 will work.
Why not just stick w/ 8" wheel or 225 rubber? (or BOTH)
UrSoccer_mobile®
17
10-22-2003 10:19 PM
Clues
Performance and Tuning
05-16-2001 09:04 AM
