Wheel liner - what is the best way to get rid of the edge of the wheel liner front & back?
Will I have corrosion problem in the future if I cut away the offending areas ( I will need to cut about an inch)? or can I heat up the plastic and re-form it? Any info is much appreciated.
My A4 sits pretty low - slightly tucked front and rear with 18x8's / 35 offset which causes slight rubbing on slow sharp bumpy coners for the front and dips cause the rear left hand corner to rub - the fronts fenders are rolled and it is only the plastic liners that cause the problem.
RJDS4
Pacific Northwest Discussion
09-03-2003 08:11 AM
Pekboy
07-24-2002 12:57 PM
A4agarwal
06-29-2001 02:35 PM
Thrawn
06-18-2001 09:12 PM
