Wheel problem help...
Recently I had replaced one of my wheels and tires. Now whenever I get above approximately 25-30 mph I hear a loud noise from the said wheel/tire.At first I attributed it to the tire being new and just needing break-in, however, it should have subsided by now. I'm beginning to think that the wheel perhaps wasn't balanced correctly when the tire was mounted, but I do not feel any vibration. Could it be a slight off-balance that does not transmit much vibration, but instead just makes lots of noise? TIA
its a bearing, no doubt about it, i just went through replacing both drivers...
side bearings. That is the exact same way i descibed it to my dad and my mechanic. I said "it sounds like big truck tires". I got the beraings from shokan for 55 and 80(i think it was 80), but anyway get the kit you get a new bolt and few other things, it makes it easier on the mechanic(or you). Good luck
falcindor
06-05-2006 07:29 PM
OneThirtyEight
11-27-2004 06:17 AM
