wheel spacers/adapters (universal fit?)
I saw an ad in Eurotuner last month for a set of wheel spacers which were also adapters... ie, you could have a 5x112 bolt pattern on our a4, but still fit 5x120, 5x114.3 bolt pattern wheels. Does anyone have a link or somewhere when I can find them? GF threw out my eurotuner with some spring cleaning =/
Thanks in advance.
Thanks in advance.
<a href="https://forums.audiworld.com/a4/msgs/1135829.phtml">Spacers</a>
They're 5x112 and 5x100.
I got mine from AWE. I believe ECS sells them as well.
and are 5x120 bolt pattern.. what would you recommend as the optimum spacer/adapter? should i get a hubcentric one? also, if the current offset on the wheels is ET35, and I get say, an 8mm spacer... won't that move my offset to 27mm? or does it go the other way (43mm) ?? Thanks...
make the offset 27mm. Call (818)992-5700 and ask for Fred at wheeladapter.com for more info on some custom adapters. He only charges $65 each which is much better than the $100+ you would pay for H&R adapters.
