Wheel Speed Sensors
Wheel Speed Sensors
I just got myself a 1998 A4 1.8T Quattro and have found at very low speeds the ABS seems to engage on one of the front wheels. I think one of the wheel speed sensors is the culprit but I don't know where the connectors are located for these sensors to test them. Does anyone know where the connectors are? Thanks for any information you can give.- quattrobo
How do you plan on testing the sensor?
To find the connector find the sensor and follow it back to where it plugs into the harness. Should be about a foot or so.
Ohm out the sensor, but I suspect that will pass (otherwise the ABS MIL would light). Really you would want to put a scope on it and look at it's waveform.
Might check the gap between the sensor an the ring too.
Re: How do you plan on testing the sensor?
Actually the plan was to ohm out the sensor as you said. All 4 sensors were originally seized in because it is a car from East Coast Canada and I think I damaged the suspect sensor while trying to take it out (because the MIL has come on).
I've traced the wire but it goes up into the wheel well wall and I loose it. It seems to go in under the dash. I can't seem to locate the point that it connects to the main harness. I'll keep looking. Thanks for your help though.
faciest
10
10-03-2023 12:49 PM
1.8mike
06-02-2009 11:00 AM
