wheels
i have a 2001, a4 i have 19" wheels in the back and 18" in the front. the car was bought this way. is there any advantages to having this considering the car is four wheel drive? and the car is lowered could i put 19" wheels on all four? thanks Bruno
I am not completely sure about the altered wheel size, but I have read on here some people recomending that all 4 wheels be the same size. This having something to do with the Quatrro system. I do not know for sure, I am just repeating what I remember reading. If it was me, I would make them all the same size, just so that you can rotate your tires alot easier.
You can put 19's all the way around, but depending on the width and offset of the wheel you may have to roll your fenders. I am sure someone else will elaborate more on what I have said...
not to be a a$$ but when i was looking up information about wheel and tire sizes, the SEARCH function helped grealty. You can find tons of pictures and explanation about diiferent wheels and tire combos. More likely then not, someone on here has the same wheels as you and probably the same suspension set up.
