When checking engine oil...
Old 06-09-2001, 09:06 AM
Member
Ben3.2TT@BC's Avatar
Default When checking engine oil...
should I check it when the engine is on or off? I was checking the engine oil last night and I think I got a higher engine oil level when I turned off the engine.
Old 06-09-2001, 09:40 AM
Member
Yippers®'s Avatar
Off, car level and oil warmed...wait 3 minutes for oil to settle, then check. Do NOT overfill.
Old 06-09-2001, 10:37 AM
Member
Default Thanks. More questions inside.
Is it okay to check the oil level when the car is parked overnight? I was checking the oil level on my brother's Mk4 Golf 2.0 which was parked overnight and I was shocked to see his car hardly have any oil left. Sine his car is under the oil consumption program, he drove to the dealership to report this to the mechanic and he said the oil level is fine.
Old 06-09-2001, 12:12 PM
Alf Arkin's Avatar
Default Bad! <with Dana Carvey voice> . . .
Always with engine off, you don't even want to remove the dipstick while the engine is running ... Bad! (-:
If you let it sit for a while, some more oil will drain to the oil pan, but not that much.
Old 06-09-2001, 12:34 PM
Member
oops...:-P
Old 06-09-2001, 10:41 PM
Member
Yippers®'s Avatar
Default It is okay, but the dipstick is calibrated to check with the oil heated (m)
and checking it cold will give you a lower reading. If you are close to the fill line but under and top it off, you run the risk of over filling. As I said before, over-filling can have dire consequences. If you over-fill, it is possible to introduce oil into the cat. Also, with many engine designs over-filling the oil can raise the pan level to the point that the crank swings thru the oil introducing loads on the crank that can cause damage.
I don't know what 'hardly any oil' left means but if there was no oil showing on the dipstick when checked cold, I would think that warm it would still be low. I would check it again with the engine shut off after the oil is fully warmed.
Kevin70
Audi A3 / S3 / RS 3 MKII
11-14-2015 05:11 AM
1stVR6
2.7T V6 Discussion
11-09-2006 05:08 PM
NH_AR
05-04-2006 08:12 AM
GTI---&gt;S4
04-13-2003 09:36 AM
Scott W
16
11-10-1999 01:47 PM
Quick Reply: When checking engine oil...
