Where can I find crossed drilled rotors..but not drilled all the way through. Kind of like ....
What you are asking for is slotted and dimpled rotors, The main reason for drilled/slotted/dimpled rotors is to have a place for the gases (from the pads cause of heat it pushes away the pad) some where to go, as long as you buy a quality rotor in the first place there is no problem. I have the bembro/eurorotor crossdrilled on mine with 4 drivers at the track constantly going no problems, just make sure your brake fluid has been changed with something around dot 4 600'degree fluid and good pads..
brat2.ua
09-29-2008 08:40 PM
sbmellen
01-22-2004 04:47 AM
a8silver
07-24-2002 07:34 AM
