Where is the pigtail for CD changer in '97(Delta Bose system)?
Guest
Posts: n/a
Mine was taped to the left fender behind the left trunk sidewall directly over the left rear wheel. Pull down the left side of the trunk (it helps to unbolt the BOSE amp hanging from the rear deck), and reach up into the cavity between the trunk liner and the fender. What you're trying to locate is a fairly thick bundle of wires with a small sheet of foam rubber wrapped around the end of the cable where the CD changer connects. Once you find it, just pull it over the trunk liner and plug the changer in.<p>Good Luck, finding the cable is the hardest part!<p>Robert Jordan<br>'97 1.8t
halik
05-09-2005 12:21 PM
Žob
03-09-2004 08:05 AM
IronMike
03-26-2000 03:27 PM
