Where is the sensor that reads flow for the air injection pump
I'm throwing a code for incorrect flow from the secondary air injection pump. Does anybody know what sensor reads that condition?
I plug the valve in, so I know at least one of the two valves (2.8) is opening. I'm think the pump is running, so I'm running out of ideas
The car uses the 02 sensor the check secondary air flow. Usual cause is a vacuem leak to secondary air valves. Furthermore, any vacuem leak in the car can lead to insufficient vacuem to open the valves. If your vacuem lines are cloth covered they may very well be brittle and leaking.
mobaar
07-15-2009 03:54 PM
Stoney
09-10-2004 08:11 AM
