Where's the best place online to get EBC brake pads? Also, should I upgrade my rotors...
I think my original rotors have finally worn out and was wondering whether it was worth it to get slotted or cross drilled rotors. I'm not crazy aggressive with my driving, but I also don't follow the speed limit. Does anyone know what the price differntial is approximately between OEM and performance rotors?
Thanks in advance!
Thanks in advance!
germanautoparts.com probably for the pads.. as for rotors
if they are worn out, definiately replace them. Might as well since your doing the pads. save some labor.
You can get an aftermarket slotted or x-drilled rotor for the cost of an OEM non slotted or x-drilled rotors.. less actually.. so it's not really an issue as to being slotted or x-drilled or not, it's a matter of what's the most cost effective, and if they happen tobe slotted or x-drilled, added benefit.
JD797
21
05-09-2007 01:17 PM
sbmellen
01-22-2004 04:47 AM
