white smoke
i have white smoke every now and then coming out of the exhaust of my 01 audi a4 1.8t, the turbos fine, its pulls and boost, so its not a headgasket, then i heard about a dry sump tank which i think it might be, but i just got the car i dont know where and how to drain the dry sump tank...please....help...me thanks
water vapor is normal in small amounts from the exhaust, especially when it's cold out.
There is no "sump tank". many people refer to the oil pan as a sump, if that's what you are thinking of, being low on oil would not cause white smoke, unless you had NO oil, and burned up teh motor.
AudiWorld Expert
Seriously - like the said - white is water. Blue is oil.
White at start up can be moisture in the exhaust system. If it is while you are running - could be a leak in the head or somewhere else in the cooling system
its not just a little smoke theres alot somtimes and also a little when im driving,and theres enough oil and not too much...im dont know what it is
ryandlor
Canadian Discussion
9
04-16-2008 01:47 PM
newguy662
01-29-2006 03:56 PM
NYC_S
09-23-2004 10:38 AM
blkbat
06-29-2003 08:07 PM
