Who here has done the A8 brake upgrade that is in the tech section...
... I was reading though it and noticed that the A8 rear brakes are 269mm x 20mm while the original A4 rear brakes are 245mm x 10mm. The article states that the original rear brake pads are used (10mm) so this means that the new disk will only have 10mm of the 20mm used. Do I have this right or am I confused?
I'm thinking of getting bigger brakes at some point in the future and just want to figure out what I need to get.
Kirk
Kirk
The rotors are larger in diameter both front and rear on the A8, but the caliper/pad are the same. the A8 rotors have cast the swept area further out from the center of the disc.
The rear caliper for the A8 isnt the same as the A4 (it has a 10mm wider space), but it uses the same pad. I didnt do the rear part or would have remembered that.
Personally, I dont see the value in doing the rear. The work done by the rear brakes decreases after the front upgrade. I used a precise measurement system known I call "average brake dust accumulation per day" to measure this. After the upgrade (using the same pads) and after a break-in period for the front rotors I saw an increase in average brake dust accumulation in front and a decrease in the rear.
4AudiQ
Brakes Discussion
09-11-2006 01:39 PM
hadokenny
05-23-2005 05:44 AM
JAFO
10-28-2002 12:16 PM
CP
12-15-1999 01:23 PM
