Who makes the spring with the highest spring rate?
Re: Who makes the spring with the highest spring rate?
H&R ultra coilovers and Motopersona coilovers are higher than 500
Truechoice makes a custom set up. Eibach ERS springs goes well over 1000lbs.
you are better off getting coilover with high rate
springs. Coilovers will be matched well. It will be expensive and difficult to get a well matched shock for a high rate spring. You will probably end up spending as much as a coilover anyway and not get the adjustability. Don't try to run Bilsteins with hig rate springs...I've learned this the hard way.
