why does my door lock not lock from inside the car? it makes a pneumatic sound.
Old 04-09-2007, 11:46 AM
RedBlackYellow's Avatar
Default why does my door lock not lock from inside the car? it makes a pneumatic sound.
also my remotes don't do what they should outside the car, i have to put the key in the door and twist to close up or open up windows. i went thru the cycle of reprogramming them i believe.
Old 04-09-2007, 11:48 AM
RKA
AudiWorld Uber User
RKA's Avatar
probably because the vacuum pump is failing...common problem
Old 04-09-2007, 11:50 AM
fix? and u say probably, so what else could be doing it? or is it positively the pump?
Old 04-09-2007, 11:51 AM
car locks and unlocks with remote tho.. and there is flash of lights and no horn honking.
Old 04-09-2007, 12:03 PM
jguthrie's Avatar
Faulty door switch could cause that. Alarm won't arm without all doors shut.
Old 04-09-2007, 12:39 PM
RKA
AudiWorld Uber User
RKA's Avatar
Default that's not what you said in your original post...
You stated that it doesn't work with the remotes either. In that case it's probably the pump. If you vag the car and scan the codes, you'll see a code for run time exceeded on the central locking pump, which will confirm the problem.
Old 04-09-2007, 01:40 PM
Default no the up/down windows holding lock or unlock doesn't work. horn doesn't beep.
it does seem like a door is open but i've closed all the doors and trunk and hood. The only other thing is hood sensor but i haven't checked it yet. Can't be the vacuum pump if it's needed to lock it, since she was locked about 40 mins ago.
Old 04-09-2007, 01:41 PM
how bad to check and change? I already know how to take the door apart.
Old 04-10-2007, 09:20 AM
RKA
AudiWorld Uber User
RKA's Avatar
Default Again, vag it...
if it's a door switch or hood switch that's bad, you'll probably see the code telling you exactly which one went bad. Much easier than guessing.
Old 04-10-2007, 04:49 PM
RKA, my vacuum pump is shattered it needs replacing. do you have a cheaper way than $491?
Quick Reply: why does my door lock not lock from inside the car? it makes a pneumatic sound.
