Why doesn't anyone get the 25mm neuspeed sway bar - seems everyone goes for 19mm.
Most people are happy with upgrading their springs/shocks, and maybe adding the 19mm bar if they still want improved handling.
But anti-sway bars take some independence out of your suspension, and make you rear end more prone to "hop" over bumps, which is very bad if you're pushing a hard corner & hit a bump. That's no big deal on a smooth racetrack, but can be very noticeable driving on real city streets. Makes your car drive alot more like a Mustang or Camaro with solid rear axles. The thicker the bar, the less the two sides of your car can move in opposite directions, and the more "hop" you experience.
So if you don't need that additional support, for track use for instance, then you probably don't need to get the bigger bar.
