Will 245/45/17 tires fit?
Old 05-02-2007, 11:18 AM
  #11
Durrrrty Dufour's Avatar
Default which are you saying is closest?
i just did the calculations cause im avoiding work and 245/40 is definitely closer than 245/45 but you are correct 255/40 is the closest.
Old 05-02-2007, 11:24 AM
  #12
pac1085's Avatar
yea..what you said.
Old 05-02-2007, 11:27 AM
  #13
pac1085's Avatar
Default no its not.
http://www.miata.net/garage/tirecalc.html
225/45/17 = 78.5" circ
235/40/17 = 76.7" circ
the next step up from 225/45/17 with the same circumference is 255/40/17 (which probably wont fit)
Old 05-02-2007, 11:28 AM
  #14
pac1085's Avatar
on your car with H&R race?
Old 05-02-2007, 12:29 PM
  #15
Zsolt's Avatar
Default what is the offset and width of the Moda R3?
235/45/17 is the widest you can do on S4 Avus (7.5 wide et 45). Some 235 rubs, some fit OK.
It really depends on your wheel.
Old 05-02-2007, 12:32 PM
  #16
nunya's Avatar
yep, on the highest groove all the way around.
Old 05-02-2007, 05:02 PM
  #17
Senior Member
AutoXJunkie (Justin)'s Avatar
either way it's more width with zero rubbing issues unless you're st00pid low
Old 05-02-2007, 05:04 PM
  #18
Senior Member
Default I"m *pretty sure* I'm running the H&R Race w/no rubbing when I run my 235's for AutoX
I say pretty sure because I've got less than 1 finger gap on the rear fender
Old 05-02-2007, 06:40 PM
  #19
pac1085's Avatar
Default i agree but it throws off your speedo/odo quite a bit
i wish our car was like others where you could change the ECU's calibration on tire size.
Old 05-03-2007, 02:37 AM
  #20
New Member
rip2339's Avatar
Default Re: Will 245/45/17 tires fit?
i run, 235/18' on my 01 a4 on all four corners with the sport oem suspension, no rolled fenders, no rubbing, no issues, except for tire wear, but i think thats a camber issue since i have over 110 k on the suspension
Quick Reply: Will 245/45/17 tires fit?
