Wind noise coming from window area
Lately, especially when it is cold, I have a lot of wind noise coming from the window, like it is not sealing well. I can't tell if it is the window or the door seal. It happens at 75+ mph. Does anyone have a fix or do I need to go to the dealer. It seems to only happen when it is cold out.
Thanks,
Greg
99.5 A4 2.8QMS
Thanks,
Greg
99.5 A4 2.8QMS
I had the same problem (more)
I had the dealer "fix" the problem. He adjusted the door and window frame. It eliminated the wind noise but created two other problems. One, the door is now a little difficult to close because the fit is tight. Two, the aluminum trim below the window is slightly out of alignment with the trim on the back door.
If you have your dealer work on the door, make sure it is done right.
Randy 99.5 QMS 2.8
Randy 99.5 QMS 2.8
Audivision
03-16-2003 07:03 AM
moTAP
01-21-2003 05:20 AM
Dan F
09-10-1999 07:57 AM
