window washer indicator stays on after refilling ...
Is there a way to turn the indicator light off? The level went down, I did a refill, but the dashboard is still showing the level to be low. Is there a float that might be stuck?!? Unfortunately I don't have a manual to look it up and I'd hate to take it to the dealer for them to reset it.
Any help is appreciated and thanks in advance!!
Frank
Frank
and then just unplug it, if that doesn't turn the light off, then bridge the contract on the sensor wires, and that should do it.
Not sure about why your sensor has failed, and I am not sure what type of sensor it is (float vs. wet contact). If its a float, maybe it is stuck and needs to be bumped free.
I've had 3 A4s, and have had to replace the pump on all 3 of them.
i filled mine when my light was on with a full bottle of fluid and even after that the light was still on. when i put in a little more however the light went off.
joe the god
05-04-2014 04:12 AM
Hidshadows
10
08-25-2003 08:14 AM
