windshield washer weak?
the point that the washer touch the windshield is very low, like the bottom of the windshield, is this a problem? I replaced the water pump for windshield weeks ago due to the pump was cracked.
any sugestions?
thanks
ming
any sugestions?
thanks
ming
The washer sprays either right onto the wiper arm air deflector or just below it. Last time I was at the dealer the tech said it would be a simple adjustment. I have included it on my list of things to be fixed on my warranty visit on the 26th. If its not solved before then I will tell you what they do to fix it.
I have a 2000 1.8T as well
to lack enough pressure to force the liquid stream up further on your window?
If it's misalignment, that's easily adjusted by putting a needle or safety pin into the wash jet you need to adjust, and repositioning the jet. Do this gently, or you'll screw up the jet in the process.
If there isn't enough pressure...something is wrong with the pump installation or there is some kind of blockage in the lines running to the jets. Best thing to do there is disconnect the lines near the jets, turn on the pump, and see if it will push the debris up and out of the open lines.
Ragdoll
03-16-2009 10:21 AM
Catamount90
02-21-2006 11:00 AM
