Windshield wiper fluid warning light removal with vag
I have a leak in my windshield wiper fluid reservoir, and the warning light is really annoying, anyway of clearing the light with vag?
yup
Select]
[17 - Instruments]
[Recode - 07]
Write down the existing coding for future reference.
Enter 5-digit code from below
[Do It!]
Look at the first two digits in the coding. Add the values for the options together to get the correct coding.
00 - No available equipment
+01 - Brakepad wear sensor warning active
+02 - Seatbelt warning active
+04 - Washer fluid level warning active (may only work with pre-2000 models)
+16 - Navigation System (non-USA models)
Look at the third digit in the coding (Market version):
0 - "Germany" 24 hour clock
1 - "Rest of World" 24 hour clock
2 - "USA" 12 hour clock
3 - "Canada" 12 hour clock
Look at the fourth digit in the coding (Cylinders):
4 - 4-cylinder
6 - 6-cylinder
Look at the fifth digit in the coding (Distance impulse multiplier):
0 - TDI Engine (non-USA models)
2 - Non-turbo Gasoline engine
4 - Turbocharged engine
So, if you want to have Seatbelt warning and washer fluid warning only in a 1999 Canadian A4 2.8, (add 00+02+04 = 06),3,6,2 = 06362.
[17 - Instruments]
[Recode - 07]
[Do It!]
4 - 4-cylinder
6 - 6-cylinder
Not with VAG, but...
I have the same problem. There's a reliable fix. It's probably much easier if you have small hands. In any event, find the electrical connector on the side of the resevoir. Take it off. Look at it. Bend a paper clip such that you can stick it in the terminals. Stick the paper clip in. Voila, no more light.
ImAwesome
01-09-2007 03:45 AM
beejohn
10-19-2006 02:58 PM
capn00
12-23-2002 11:31 AM
squalo555
10
10-09-2001 04:10 PM
