Wiring for remote start/alarms..
Didn't know if anyone would be interested in knowing the wiring colors/locations for putting in remote starts this is for 2001 a4...(email me if you want wiring for different year)
12volts red + ignition harness
Starter red/black + ignition harness
Second Starter
Ignition black + ignition harness
Second Ignition
Third Ignition
Accessory yellow/black + ignition harness
Second Accessory
Keysense
Power Lock brn/gry or red/brn - drivers kick or alarm
Notes: Factory alarm is on the bottom passenger side of the trunk.
Power Unlock gray/white - drivers kick or alarm
Notes: Unlock requires double pulse.
Lock Motor
Unlock Motor
Parking Lights+ gry/blk & gry/red headlight switch
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger brn/yel & brn/wht -
Notes: Brown/yellow in the drivers kick panel gets the drivers door, brown/white in the passenger kick panel gets all the other doors. Use both wires and must diode isolate from each other.
Dome Supervision use door trigger
Trunk/Hatch Pin white/black - alarm module
Hood Pin brown/yellow - at hood pin switch
Trunk/Hatch Release yellow/red + at switch
Power Sliding Door
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock
Tachometer green/blue instrument cluster or
Notes: Tach is also found at the ECM on the driver side firewall.
Wait to start
Brake Wire red/black + at switch
Parking Brake
Horn Trigger black/yellow + horn relay
Memory Seat 1
Memory Seat 2
Memory Seat 3
Immobilizer Bypass Module: Required: Yes Type: Transponder Part #: 556U, 555B, or 555U
Notes: See DirectFax document 1056 for additional wiring information.
This wiring information is being provided free of charge on an "as is" basis, without any representation or warranty. It is your responsibility to verify any circuit before interfacing with it using a digital multimeter.
Directed electronics, Inc. assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information.
Second Starter
Second Ignition
Third Ignition
Second Accessory
Keysense
Lock Motor
Unlock Motor
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Power Sliding Door
Disarm No Unlock
Wait to start
Parking Brake
Memory Seat 1
Memory Seat 2
Memory Seat 3
Yes, just use a neutral safety switch, or use negative output trigger from the remote start to go to the clutch (if you do the neg output you have to leave the car in neutral, leaving it in gear it will still start).
hi, i was wondering if you can help me.
01 audi a4 1.8t 5spd
i would like to add a remote start to my factory alarm system, is there anyway you can program it to the factory remote?? someone told me i can if the alarm has a 2nd channel output. if not can i just add on to the factory alarm and just carry another remote? they were telling me that i would have to buy an immobilizer?? i currently have a turbo timer wired in and works perfect,
roughly what would be the prices out the door, parts and labor for the remote start?
thanks for you help, pj
im assuming the car with the key flashing on my dash is the immobilizer?
my problem is i had to take the key cylinder out as it was broke. i am broke and can not afford a new key or anything else. how can i program the keyless fob without having to stick a key in the ignition i do not have?
Second Starter
Second Ignition
Third Ignition
Second Accessory
Keysense
Lock Motor
Unlock Motor
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Power Sliding Door
Disarm No Unlock
Wait to start
Parking Brake
Memory Seat 1
Memory Seat 2
Memory Seat 3
Second Starter
Second Ignition
Third Ignition
Second Accessory
Keysense
Lock Motor
Unlock Motor
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Power Sliding Door
Disarm No Unlock
Wait to start
Parking Brake
Memory Seat 1
Memory Seat 2
Memory Seat 3
Autobahnjs
Audi Original "S" Cars
11-21-2006 03:26 PM
Sometimes alarm doesn't lock when I lock the doors and lights inside the car doesn't shut off (more)
turbovet
01-28-2000 10:39 AM
