worn spot on steering wheel
after 6 years of use my steering wheel has developed a wear spot at app. 12 o'clock. does anyone know how or even if it can be repaired. it is not very large about .25 inches in diameter and I dont want it to get much worse.
Stop driving like a pimp with your hand at 12 o'clock? ;-)
Seriously, mine has a spot at about 10 o'clock and I've tried everything. The only thing you can do is keep it conditioned with leather stuff... but that can make it a little slippery. I gave up.
my cherokee had a spot on the top that eventually wore down and ripped
I picked up a fitted leather cover from wheelskins.com. The steering wheel on the xj jeep was very thin (compared to my zj grand cherokee) so the addeded thickness of the wheel cover was a plus which I do not think it would be to great for the a4. I put it on and painfully stitched it in place, then a week later removed the stiching and pulled it off then put it back on and re-stitched using what I learned the week before to make it perfect, the steering wheel looks factory and feels great but it was a pain in the a$$ to put on.
so if you really are irritated w/ the problem and don't want to deal with removing the airbag and whatnot to replace the steering wheel a wheelskin leather steering wheel cover may be an affordable answer.<ul><li><a href="http://www.wheelskins.com/">http://www.wheelskins.com/</a</li></ul>
Yea mine is only slightly worn but the top 1/3 facing the driver looks bleached
Mine only shows a little wear but it seems almsot bleached, and i dont know how it happened or how to fix it. It was like that before i got it and i bought it used.
Devius
11-13-2006 08:26 PM
nverfollow
01-05-2005 11:41 AM
