Is this worth it? Phenolic Intake Manifold Spacer
#21
I think I could see the same performance by making an IAT sensor Phenolic gasket
#23
the sensor in a pure sense measures the intake AIR temperature. it should be tolerant of sensor base temps, i.e. changes to the supporting structure, i.e. the intake manifold.
whether the intake manifold is 32deg F or 200 deg F should not matter to the AIR temp sensor.
the fact that the manifold temp does effect the IAT sensor does NOT mean the IAT sensor is giving "false" readings, if anything the manifold heating the sensor up would cause "false" IAT readings (since an insulated manifold will always track near ambient temps)
will, you and i have talked about this and we're basically in agreement, but the original poster is in error.
#24
If you watch the reading on the IAT sensor, it will actually spike when you let off the gas.
When the throttle plate closes and there is no more fresh intercooled air passing by it, the temperature reading can spike 30+ degrees. That is simply because the IAT sensor is registering the heatsoak that it picks up from the manifold.
#25
when i said "false IAT readings", I meant that it will register heat soak from the manifold...so it is still giving accurate readings, but they are inflated due to the temperature of its supporting structure.
#28
I am saying that a phenolic spacer doesn't allow heat from the head to heat up the intake manifold (that's a GOOD thing), and hence your IAT sensor won't give inflated IAT readings.
From the beginning I have been saying that phenolic sensors are GOOD...i just didn't make my first statement very clear.
