would a bad bpv hold a constant boost? mine holds a constant 10psi
The colder air could cause you to run lower boost, but I don't think it would be that low. Are you sure your chipped?
Try to VAG your car and check the actual vs requested boost levels, and check if you are throwing any codes.
