would a bosche 5.3 abs controlerfrom a 99 work in a 96 a4 2.8 that origionally had a 5.0?
Old 10-19-2004, 09:34 AM
  #11
Phil type 951's Avatar
Default that could simply be a wheel sensor issue
have you had the brakes or wheel bearings worked on?
can the vag talk to the abs computer?
clear the codes and see what happens
if you can talk to the abs computer with the vag its prob ok.
Old 10-19-2004, 09:38 AM
  #12
Default you dont have anything under the seat
that was an older style abs system
when you order it just make sure that is the part# you get. make them read it back to you or something becase sometimes they fiqure if its out of an a4 it will fit any a4.... not true.
Old 10-19-2004, 09:52 AM
  #13
New Member
Skeepa's Avatar
Default I just got a quote from Dad's Auto for $850 for that same used part.
Seems like a lot compared to what others have been paying.
Old 10-19-2004, 10:18 AM
  #14
sbmellen's Avatar
Default OK, now I'm REALLY confused. The *actual* pump/motor assembly under the hood is a...
<center><img src="http://pictureposter.audiworld.com/19556/hpim1004.jpg"></center><p>8E0-614-111-M, not 8E0-614-111-N like the dealer specified to me in writing.
??? Where could 8E0-614-111-N be, if it isn't what is pictured below?
<img src="http://pictureposter.audiworld.com/19556/hpim1005.1.jpg">
Old 10-19-2004, 10:25 AM
  #15
odelay12v's Avatar
Default i pulled the abs fuses because the amount of pulsing of the abs at almost all times now..
cant be good for anything now it is just turned off..
Old 10-19-2004, 10:29 AM
  #16
odelay12v's Avatar
Default not prior to the problem only after the problem..
i have since this started about 2 weeks ago.. cleaned all 4 abs wheel speed sensors and the copper or brass holders that the sensors seat in.. also replaced my rear rotros and pads and front rotors and pads and bled the brake fluid a few times and also replaced the brake lines in the front before all of the replacements it happened once in awhile now after cleaning it happens all the time.. i replaced the wheel bearings about 2 years ago..
Old 10-19-2004, 10:38 AM
  #17
New Member
Skeepa's Avatar
"N" replaced "M"
Old 10-19-2004, 10:44 AM
  #18
sbmellen's Avatar
Really? So, "N" is the same part (whole pump/motor assembly), only upgraded engineering?
Old 10-19-2004, 11:16 AM
  #19
New Member
Skeepa's Avatar
Default This is the email i got from Dad's Auto...
Daniel,
The abs pump part number 8E0 614 111N is the new dealer replacement part for the 8E0 614 111M which we sell for $850.00.
Please call 1-800-321-3237 and ask for TIM to place your order or for further assistance.
DADS AUTO DIASMANTLING
5920 Outfall Cir
Sacramento, CA 95828
916-388-8350
Old 10-19-2004, 03:37 PM
  #20
Default good now if you are sure that is the part you need to replace
then go on www.car-parts.com and see what you can find an m box for. dads is a great palce to get stuff but that is still a ton of cash.
Quick Reply: would a bosche 5.3 abs controlerfrom a 99 work in a 96 a4 2.8 that origionally had a 5.0?
