Would like to trade: Jack/Rat Terrier mix for ATW engine.
#12
I would bet that if you did a serious flush with Kero/diesel etc and drop the pan then continued to flush it out and down it would be fine.
The oil pump is probably getting clogged with bits of plastic hence it taking 5 minutes to clog and trigger the oil light.
Sure it's taken life off the engine... but run it till it blows! (It may last 100K miles or more)
#13
And he's worked with audis a bit. since it runs and even sounds good, I tend to side with you and Joey... but I'm also not a mechanic, and the mechanic who's seen it is. I can't believe an engine that fires right up and drives can't be fixed though!
#14
If that's the case he should just say that....... drives me nuts how many mechanics I know that are great mechanics but fVck themselves by BS'ing and/or getting in over their heads.
I'm not saying he's doing that.... but it sounds to me like he doesn't want to deal with it for *some* reason. I would not hesitate for a second to at least drop the pan, flush it out VERY VERY well and see how things look. No way he can say "it can NOT be rebuilt" without looking at it a lot closer.
#15
.... he's just saying it may not be worth the time and money in buying a new cam tensioner and oil pump when the engine could fail in 5k miles.
He's a friend of a friend, and he'd drop in a new engine for free, but he's also an all around mechanic. Joey, for instance, I really think that he could rebuild it..... and I'd rather pay Joey to do it than have to pay for a new engine.
On the other hand, I'd feel bad towing it out of this guy's shop.
It's a tough one.
It's a tough one.
#17
Pull the motor and drop it at Joe's so he can build it, then have your friend / mechanic instal?
Honestly if it's properly cleaned out and pulled apart (a light rebuild in other words) it will be as good as any motor.
#18
... This car fires right up! How could it need a new engine? Is that even possible? I've known Joey for like 4 years now and I trust him.
I CAN however see little bits of plastic inside the engine with the valve cover off... but that must be able to be removed and/or flushed out.
