would upgraded injectors do me any good?
i currently have a 99 1.8t with an apr chip and am looking to get a little bit more power out of it, someone suggested upgrading the injectors. what is involved in doing this, how much does the reflash of the ecu through apr cost? how much of a power gain will this upgrade give?
What do you mean by "upgraded"?
If you mean injectors that flow more, then no.
If you mean a higher-quality injector, then maybe. I could see a new RS Injector or something similar providing a better or more consistent spray pattern than the OEM injectors with 100,000 miles on 'em. That said, I wouldn't bother with it. If you have a lot of miles on yours, maybe have them professionally cleaned.
Dealer changed all of ours to the "red top" version under warranty....
It seemed they had some issues with injectors in these cars and went through some different versions. The car(00 30v) was idling terrible when new , so I complained, they replaced all the injectors under warranty which improved the running. No more power,not a slam dunk, but better running and mpg. My guess is that the spray pattern is better and provides improved detination. You would probably do better going after market.
NJWilliam
10-22-2006 12:57 AM
JBSMOOTH
24
03-24-2006 06:09 PM
90/90Qs
14
10-04-2004 04:24 PM
jquattro
16
12-12-2002 07:59 AM
