would you like to aim your projectors in the comfort of INSIDE the car?
still awaiting even more parts, lit rocker switches to enable pot, 2 pots; one for adjusting base line, and/or fixed resistors values....
and a factory switch with preset levels.
I'm comparing the two to see which one i want to use. Variable would be best as i can fine tune the level to any driving/load in the car. I wish i had it on my drive down to LA on the I5 since i drove at night.
other ideas is a momentary switch near steering column so i can have a quick "higher" adjustment of my euro xenons (without them being "high beams") for freeways or highspeeds.
Should get all the parts in mid dec. stay tuned
<img src="http://wsphotofews.excite.com/013/ES/UV/Vn/TQ70173.jpg">
also, the switch is just a level switch with fixed resistance values
IIRC, there is still a controller that adjusts micro movement based on the negative feedback of the onboard pot. I've got RC parts to play with that work just the same. should be interesting.
