x post: performance board, questions about camber problems.
I have some wear on the inside of my tires due to lowering. I would like to eliminate this problem completely. I am interested in getting a camber kit that being said I have heard some negative things about AWE's CPP links. What are some good recommendations? Thanks. BTW, I did get the car aligned after I lowered it.
Here are the specs.
Left front
-1.0 camber
4.8 caster
0.27 toe
right front
-1.2 camber
5.1 caster
-0.56 toe
Wear in the rear looks fine. I have specs for them as well, if needed.
Here are the specs.
Left front
-1.0 camber
4.8 caster
0.27 toe
right front
-1.2 camber
5.1 caster
-0.56 toe
I am not terribly low, but tread wear is enough that it irks me
only 1/32 difference across the length but with the tires I am getting I don't care to be replacing them earlier than I have to. $$$$
i'm also FWD, guess i wont be getting koni coilovers...
my next mod is coilovers...and i had really bad camber wear on my last car...and spent so much $$$ on tires. Guess i'll avoid konis since they give neg. camber wear...w/ only a slight drop
