Xenon fog lights
if you want a real xenon kit, you will probably have to design it yourself. OEM xenon healights are 4,300k btw.<ul><li><a href="http://www.supremepower.com/category/lighting/spplight.html">http://www.supremepower.com/category/lighting/spplight.html</a</li></ul>
Another possibility is to pick up the H7 Gold (Yellow) 55W bulbs which also look really nice with xenon headlights. For the installation you will need to remove your bumper/wiring. If you don't know what to do, take it to a shop and they should be able to finish the work in around 1 hour. Once the bumper comes off it is easy to change the bulbs, but if you are working alone and without a lift, getting the bumper back on will be tricky. just some heads up.
There is only 2-3 screws from the front if you remove the lower grill inserts. Then you can pull the whole fog assembly out. I find it much easier to do it this way because then you dont have to get under the car to remove the belly pan.
pr0digy30
06-18-2007 01:45 PM
Sacer
08-04-2003 09:10 AM
Eddie2OOO
Audi 100 / A6 (C4 Platform)
03-28-2002 12:31 PM
Big D
02-01-2002 04:48 PM
